The car does not respond the key
Hi everyone!
The car stops seeing the key in standby mode.  More: I turned off the car, got out, the key button closes normally. If you immediately click on the open button, it also opens normally. But once the car gets in standby mode, it stops responding to the key buttons. The car can only be opened by touching the door handle. That is, keyless access works fine, but the buttons in the key stop working. Is any ideas?
Have you tried a new battery in the key fob ?
Yes
Try this (from the owners manual):
The vehicle cannot be unlocked or locked with the
remote control
There may be the following reasons:
▶ The battery in the key is empty.
› Replace the battery » page 23.
▶ The key is not synchronized.
Synchronize the key as follows:
› Press any button on the key.
› Unlock the door within 1 minute with the key via
the locking cylinder » page 25.
If necessary, the key must be synchronized if a
favoured button on the key has been repeatedly
pressed outside
Already done.  Still have the issue.
What new battery did you fit in the fob? The fobs are incredibly sensitive to the battery voltage and internal resistance.
Agreed! I went through batteries at an alarming rate initially, then started using Panasonic CR2032PG/18's which last for ages.
Just used Panasonic. Nothing changes.
Edited by Zheka79
