Drivers fwd seat belt replacement
Hello,
Very new to this site.
Just looking for some help in regards to some errors which have come up after removing the drivers side fwd seatbelt to try and find the part number.
Before removing anything I disconnected the battery, I then proceeded with removing the trim and then started with the belt assembly. I disconnected the connector for the belt tension, and then the other fasteners attaching the assembly. Once the part number was found I refitted everything and then trim, reconnected the battery and subsequently the following cautions came on once the car was switched on. (Error start stop system, error stabilisation control, error tyre pressure monitoring system.
I have checked fuses and everything seems ok, I haven't connected a fault diagnostic tool as of yet.
Any help would be appreciated thanks
Those errors come up because of disconnecting the battery and usually disappear after a short drive.
@PetrolDave Thanks sorted
