Double Floor retrofit?
Well, i cant find original parts for the double floor of the luggage compartment, does anyone know where can i find them?
i found this picture but i cant find the pieces on sale anywhere
doppiofondo fai da te
Edited by Chris_24
Added picture
I believe you're wanting item 2 HERE (catalogue for 2014 Euro build Yeti).
Nono i mean like the full double-floor assembly, i got the stock things without the spare wheel assembly
Like this, the lateral structures too
After spending nearly an hour searching through the parts catalogues all I could come up with was what I posted.
I know that @J.R. did some work around false flooring in his Octavias and Yeti so he may be able to help.
Thank you so much for searching this much man, cheers
I actually stumbled across the original accessories booklet, and i found this
Edited by Chris_24
Ok i fixed the image
Try Here Chris.
www.kopacek.com/yeti/
If all else fails, send a picture to nearest scrapyard dealers.
Edited by Carlodiesel
9 minutes ago, Carlodiesel said:
Try Here Chris.
I only found the top rubber carpet, nothing else
Try sending them an email with the pictures.
See if they can come up with something.
