ACC Retrofit for Scala
Hi,
I want to retrofit active cruise control into my skoda scala 2022 1.0 TSI. The car has front assist and standard cruise control. I know, there is a need to change shifter to 5Q0953521MG/5Q0953502AL/5Q0953569F, but do I need something else? Of course I would apply proper coding via obd11. Thanks in advance for help.
Edited by adam3278
Add car model info
It's adaptive cruise control. Are you confident that you will be able to successfully code it? I can't code my 2022 SEL to activate traffic sign recognition ... apparently from 2022 certain coding is hidden or locked down.
I don’t know if I would be able to code it manually by myself, but there’s also one click app in obd11 especially for that.
Maybe coding isn’t the problem, but parts are. I don’t know do I need to replace something other than shifter? In my octavia III there was a talk about some pump when I wanted to do the same thing, but there was no front assist too.
Be very cautious if you intend to use 'One Click' coding - it can result in unwanted, and difficult (or impossible) to reverse changes. You would be strongly advised to download all existing settings before making ANY changes.
Ok, I see that I need proper shifter, radar and abs module installed, based on the thread
As far as I know, I need to change shifter only and code it. Is the obd11 capable of enabling feature codes, or I would need help from vag retrofitter with proper software?
  • Sponsor
TSR is SWaP. We can activate it for you
https://eastyorkshireretrofits.co.uk/products/2q0-traffic-sign-recognition-tsr-vze-full-activation?_pos=1&_sid=d18989093&_ss=r
  • Sponsor
On 25/12/2024 at 21:55, adam3278 said:
Hi,
ACC is SWaP. It isn't possible to DIY. We can activate ACC for you. Please send us a message with your reg or VIN
