Indicator issue
Hi.
2019 1.5 Sel. I hope this makes sense...
The indicators operate perfectly when you press them down to the position where they stay on until the wheel is turned.
The problem is when you just press the stalk gently- such as changing lane on the motorway- instead of flashing 3 times, I only get 1 flash.
Same issue whether its left or right.
Any thoughts? Relay?
Check the options for convenience flash is ticked in the settings.
If it worked before, are you using a different key as some settings are key specific.
Perfect!! I now have 3 x flashes- thank u.
