Replace 8" to 9.2" for MIB2 Amundsen to MIB2.5 Columbus
Hi all, I replaced my Amudsen unit with Columbus with sim reader. It should be plug&play but I can't get the possibility to add the parameters for the sim card (APN etc). Can someone help me? How do I add this possibility with OBDELEVEN? I saw that in the changes to be made there could be the enabling in the 5F module at byte 15 (Baseplate & Antenna Baseplate) but nothing happens. What other changes should I do? Other modules? Thanks
@pab567 Can you help?
I can try... @magiel pls post VCDS adaptation channels map or OBD Eleven backup from 5GF unit with coding and adaptations.
In attach.  I have tried to enable byte 15 Baseplate and Antenna Baseplate, but no results. Many thanks
history (1).txt
Change adaptation channel "WiFi_Client_HMI" to "On".
Make sure NAD module is turned on in coding (I think byte 15, bit 3, but not 100% sure).
Thanks, I'll try these settings and let you know if they're ok
Hi, I tried the suggested settings. Now everything works. Many Thanks @pab567
