Tyre Pressure Problem
Tyre pressure symbol came up on dashboard. Checked tyres they were ok but pumped them up a bit and reset the menu system. Light extinguished on dashboard Skoda connect app still shows a fault. Reloaded the app but tyre error still shows on the app.
If OK means none of the tyres had lost pressure since the last time the TPMS was set, or none had increased in pressure with a Brake binding or a bearing going and the hub wheel heating then all good.
Not a tyre pressure issue just an App issue.
Car to phone communication issue.
How far have you driven since resetting the TPMS on the car?
Edited by Ootohere
On 23/02/2025 at 13:56, Routemaster1461 said:
Do you mean the original 3 year warranty? Might be worth enquiring how much an extended Skoa warranty would cost.
On 23/02/2025 at 14:40, chills said:
Aren't they very different cars on the same chassis?
On 23/02/2025 at 17:18, mistac said:
Not that it might make any difference, but the direct SEL replacement is the SEL edition not SE edition (SEL edition is a bit plusher than the SE edition)
Only driven anot 10 miles since resetting.
Despite the Skoda Connect constantly reporting a tyre fault and constantly refreshing, eventually the app reported no problem! Certainly not reliable.
