rear passenger door window bust
the rear door window is not winding down.when i push the window down,it drops and when i wind the window shut,it shuts ok.
so i need instructions how to remove the door panel and clip the window back in.
thanks
1.4 16v x reg
if you do a search on here for rear door water leaks , iirc someone posted pics of how to repair the leak which involves the removal of the trim and inner panel which has the window regulator fixed to it , just follow those instructions and you cant go wrong
looks complicated and rather not risk it.i think the window has come off it's 'cradle',this happened in my old fiesta and was easy to fix.
how much would it cost at an ex skoda dealer and how long would it take ?
thanks
