Felicia side air vents
A quick question for anyone that has a felicia.
My side air vents on the dash (the adjustable ones) hardly push out any air at all with the majority coming out of the centre two vents. Just wondering if they all do this or if I have a fault somewhere. TIA.
IIRC they are only fresh air vents from the exterior and not connected to the blower ducting.
I was thinking that today actually - like lummox said, they do just feel like fresh air vents; when you have the heater on full, the air comming out of the side vents is no-where near as hot as the air comming out of the middle vents...
makes sense, did read the manual, however, it was not entirely clear.
i thought of you today ;) hot out so shut the windows, closed the centre vents and smacked the blower on full
the lower 'adjustable' vents have a very very small air flow to them, this stops when you put the centre vents back on. So they are connected. In winter its those that keep the side windows clear, thinking that in winter you use windsreen and close centre anyway, thus those other vents get a small flow, enough to demist. The top smaller vent by the mirror adjuster??? no clue if anything even comes out of those?
