Gear Lever **** Loose
Hi
Recently joined the forums having purchased a Fabia VRS just before Christmas..
Anyway having noticed a rattle / vibration on the gear lever whilst in neutral, I returned to the dealer who initially stated the problem could lie with a cable and a modification was available.
Having taken it in, the problem was subsequently identified as the gear linkages and this was duly replaced after the parts were ordered.
Problem solved...
However since they've replaced the gear lever gator and top bit (****), if that makes sense, the top part can be twisted from side to side which is somewhat annoying i.e. the markings on the gear lever 1st - 6th etc, in essence are not in alignment
The gear lever top part would appear to be held on by a metal O ring which they look to have squeezed together to tighten it...
Is this right ?
Anyone any thoughts.... :)
Nice forum board by the way....
Yup that is correct.
Welcome :)
