Help Please
I have a 2013 L & K Auto 4x4 Estate which continues to be a decent drive.
However, recently I have noticed a fairly low volume creaking sound when turning the steering wheel, primarily when parking..
It is really only noticeable when the radio is off.
My garage initially thought it may be a CV problem but that seems to have been ruled out
They then thought it could be caused by a front suspension mount which was replaced but this didnt stop the creaking.
They are at a bit of a loss to determine what causes the noise.
Would appreciate any thoughts which I can pass onto the garage.
Is it like a sharp metallic crack when turning slowly at full lock or turning the steering wheel when stationary. Is it more noticeable in dry weather?
Thank you for your reply.
I have only noticed it in the past month and it can only be described as quite moderate creaking sound that is really only noticeable when undertaking a slow procedure such as parking.
Definitely not a cracking sound. I experienced such a sound when one of the car's tie rods was damaged by a pothole.
keeping an eye on this post as my car is having a similar issue , sounds like the tyres are been scrubbed on the road but as you say its only at parking speed . its going into the mechanic on monday evening so will let you know what he finds.
Edited by brens-skoda
Definitely not the same as mine then. I will get the tie rods checked.
