Squeak noises in right engine side
Hi everyone
I´m typing from Portugal and follow this forum since 2016. I have one skoda superb 2016 2.0 TDI 150BHP.
Since 2019/2020 more or less, the car starts making squeak noises coming from the right side of the engine ( perception only ), only when temperatures outside are higher than 28/29 degrees ( mostly on summer ) and I have the air conditioner turned on.
The phenomenon don´t appear if the AC is turned off even if the outside temperature reach much higher levels.
So my assumption is that could be related with the AC function. In the service workshop nothing unusual was found.
Does anyone here having this kind of behaviour in their skoda´s ?
Best regards
Edited by filipedgmc
Hi,
We could do with a bit more information to help identify the issue, I think.
Does the noise have a continuous “tone” if the engine is idling or at higher RPM or does the noise make a faster, higher pitch when the engine speed is increased?
Is it audible continuously or is it intermittent?
Does the noise appear when the car is stationary, being driven or both?
If it’s only audible when it’s being driven, does the noise correlate to suspension movements?
Hi nunskull
I will try to summarize a little bit more with the things that I could identify:
  • Noise have a continuous pattern, sometimes correlates with suspension movements but more audible in lower speeds ( < 55 mile/hour ). But as soon as it starts it continues until the car stops.
  • Noise only appear with AC turned on ( similar on manual or auto mode ). If AC is turned off the noise completly disappear after 15 min more or less.
  • Noise only appear with external tempearture above 28 to 29 degrees
  • The noise stop as soon as the car stops, but still having the engine and AC working ( in a red light for example )
  • Noise is not affected by higher or lower engine RPM
Cannot make an correlation between the AC and suspension neither the service workshop.
Get the AC recharged.
Even with the AC don´t having problems in cooling the car ?
I had exactly the same sound as you describe. It was a lack of refrigerant in the system. Once (the leak in my case was repaired) it was regassed, the noise disappeared.
Boom. There you go OP - get them to check for leaks first rather than just refill it.
Thanks for the reply numskull.
in mid September the car will go to the annual service and I am going to follow you tip. :)
