TT Dampers on Octavia RS? Good Idea?
Has anyone done this?
The RS is running H&R springs with Sachs stock replacement dampers at the moment. But the dampers are far too soft.
Sachs list a sport damper but the stock is so soft Im not sure if Sachs "sport" will be enough.
So I was looking at TT dampers because they appear to be stiffer.
I say stiffer because Monroe for example has one code for Octavia RS which is the same as normal A3 quattros.
But the S3 runs another code which is also used by all TTs.
If S3s are running stiffer dampers than normal A3s then the TT damper will be stiffer also.
So my question is.
Is anyone aware of a huge problem in fitting TT dampers onto an Octavia RS?
Im running Audi A3 8L coilovers on my Octy 1.8t 4x4 no worries almost same weights and specs.
/R
