Standard or Sports Suspension OEM query
My 2014 Tour De France estate (140BHP 4x4) has now done 98k miles and is needing a bit of time/money spent on refreshing the suspension.
I was looking at Bilstein B4 shock absorbers which are OE spec but there are two varieties.... 'standard suspension' and cars with 'sports suspension'.
I'm not really sure what spec was standard on this model and wondered if the code label in the boot would confirm ?
Was going to start with the rear which has already had lower arms and springs for the MOT last year but the rest is needing looked at.
Anti roll bar is particularly crusty along with the shock absorber tubes.
Scottish winters and road salt haven't been kind...
Dave
The below Bilstein B4 shock absorbers for the Superb MK2 are for standard ride height, ie. not lowered ride height or increased ride height.
Front shock absorbers (standard ride height) (2014 Superb MK2 estate 4x4)
3C0413031AQ G02
3AA413031M G07
3C0413031AT G07
3C0413031AS G15
3C0413031AB G52
Rear shock absorbers (standard ride height) (2014 Superb MK2 estate 4x4)
3C0513049AR 1JA+1X1
Bilstein B4 22-151056 front shock absorbers (standard ride height) (sold to replace 3C0413031AQ, 3AA413031M, 3C0413031AT, 3C0413031AS, 3C0413031AB)
https://www.autodoc.co.uk/bilstein/632208
Bilstein B4 19-151069 rear shock absorbers (standard ride height) (sold to replace 3C0513049AR)
https://www.autodoc.co.uk/bilstein/631759
The white label in the boot only has about 40 of the car's build codes, whereas the car might have around 180 build codes.
There's a seller on ebay that can supply all of the car's build codes for 3 Euros (about £2.61).
Search "skoda vin decoder" on ebay to find a seller that can supply the car's build codes
https://www.ebay.co.uk/itm/226517872578
VW Code Decoder
1JA=standard ride height
1X1=4x4
https://igorweb.org/equidec.aspx
Edited by Carlston
Hi Carlston, Many thanks for this detailed information, really appreciated. I'll check out that VIN decoder as that seems very useful to have. I'm assuming that my car has standard suspension at the moment unless I find out otherwise. Cheers Dave
