DQ200 Gearbox - Which fluid was changed from mineral to synthetic ?
Hello, I actually own a VW Polo GT with the infamous DQ200 gearbox (Gen 2 I believe) but the Briskoda forums seem to have the most detailed topics and discussions regarding this infamous gearbox which is why I decided to create an account to clear up something I was unsure about.
Short Version : The DQ200 has 2 fluids - "Gearbox Oil" and "Mechatronics Fluid". Which one was changed from synthetic to mineral during the recall ?
Long version : While discussing this gearbox most people seem to play a bit fast and loose with the way they refer to these two fluids in the various discussions I have seen on the internet and while I was convinced earlier that it was the Mechatronics fluid that was swapped, I now have a pretty strong doubt that it is actually the Gearbox oil that was actually "upgraded" from synthetic to mineral.
All the discussions I came across said that the synthetic fluid had a high sulphur content which caused corrosion and enough of them said that the high sulphur content caused CORROSION OF A CIRCUIT BOARD leading to failure as far as I know only the mechatronics unit has a circuit board that comes into contact with the fluid and thereby assumed that it was the Mechatronic Fluid that had to be changed.
Then I came across this thread : https://www.briskoda.net/forums/topic/444027-201718-dq200-dsg-34f7-service-campaign-any-further-issues/
A couple of posts down it has a picture of a bill from the recall and the part number and quantity match the Gearbox Oil used in the DQ200.
So as a result of that I am thoroughly confused as to which of the two fluids used in the DQ200 got swapped to mineral due to the way people refer to these fluids and also the mentions of a corroded circuit board that I have come across which is why I created this thread for a straight up confirmation to sort things out at my end just for sanity's sake because I would like to keep the car a while longer and would like to avoid a fat bill down the line if it can be avoided.
I have actually changed both of these myself as a precaution when the car touched 50k using the VW fluids for both, since the VW dealerships refuse to do a fluid change and claim that the gearbox is sealed for life and has no drain interval. It was also VERY hard to get both VW branded fluids in the aftermarket so I am keeping options open for non VW branded fluids for the next change and doing my research for it. The gearbox oil is just 75W90 manual transmission gear oil but mineral based right ? Any standard that I should look out for when looking for alternatives or is there a synthetic option that is low sulphur that I could use ?
I also wanted to confirm something about the gearbox oil volume. I know that the standard fill volume is 1.7L. Some of the replacement guides I referred to recommended refilling the same volume of gearbox. However I could only drain about 1.3L of gearbox oil which I felt was too low especially since I live in a hot tropic climate and drive in heavy traffic quite often so I refilled the standard 1.7L of fresh gearbox oil. Some research tells me that the MAX oil capacity for the gearbox is 2L to the brim and even if you do fill more than the recommended 1.7L, its not a big deal. Is this true ? No problems after a few thousand Ks of driving post the refill. The old oil itself wasnt too bad but obviously new oil is better and Im sure that having the right volume also helps.
I may have gone overboard but I recently bought an accumulator upgrade/repair kit and I plan to preemptively install it rather than wait for a failure that is relatively common and would lead to me being stranded as I regularly do a couple of road trips a month. The kit came with Ravenol SFF synthetic hydraulic fluid and I plan to use that when I fit the accumulator. Is that fine or should I stick to the VW OEM hydraulic fluid ?
Lastly, is there an easy way to replace the Mechatronic filter without disassembling the whole unit ?
Apologies for the wall of text and thank you for any insight in advance !
Hi, welcome.
Sorry I know very, very little of the DSG other than I've never liked the idea back from original Aldi TT days (that VW model had loads of initial issues). Hopefully others will follow with more and better information.
If you have not already done so you could look in other VWŠkoda model forums on this site about the DQ200 which might give firmer information and/.or conformation.
I don't know but would guess the change from mineral to synthetic was about the make up of the oil rather than just a synthetic versus mineral oil issue. Whether the original oil make up was another VW error or the error of the oil supplier I've no idea but would think the oil supplier could blend to customer's instructions.
So whatever brand is your choice for oils I would contact them to find out what their database has for which oils. I don't know which oil company was the original supplier and which oil company provide VW labelled oil bottles now (VW put a Quantum label at the moment).
@Guest_ often posted information abouts DSG boxes, as in that thread you linked to.
There are are YT videos of DSG boxes being serviced but sorry I don't know if they include the DQ200 or if there are any good videos on it.
Good luck.
On 13/10/2025 at 16:25, nta16 said:
Hi, welcome.
Good luck.
Thanks. I know that the synthetic oil was causing issues due to a high sulphur content. As such I have been through a lot of threads, including ones on this forum and Im just looking for an answer in black and white along the lines of "It was the gearbox oil and not the mechatronics fluid that was switched to mineral" because while it is being discussed, there is no explicit mention of which of the two fluids it is.
As I said, I came across mentions of the sulphur in the oil causing a PCB to corrode and as far as I can tell, there isnt a circuit board in the gearbox section and then there is an invoice from the recall in the thread that I linked which mentions that the fluid that was changed out was the gearbox oil so theres a bit of a conflict happening in my mind which Im trying to sort out.
The World Wide Recall in 2012 which excluded Europe had the Synthetic Oil in the MCU changed to Mineral oil.
That was a Service Campaign in the EU / Europe / UK from 2014 with a Software Update.
'34F7'.
In NZ all the vehicles with a DQ200 DSG got a new MCU as well.
What age of DQ200 are you servicing.
2009-2012 late are the ones with the issue. Late 2012-2013 were not done.
2013-2015 is Service Campaign '34H5' a software update.
http://briskoda.net/forums/topic/501052-dsg-gearbox-oil-auantitycapacity
Service Campaign Invoice.
Edited by Evolution13
Thanks for the link (and link from link).
If the articles are correct then it certainly looks like I'm probably right with VW falsely blaming the synthetic oil to cover their design and build compromisers and mistakes. -
"The fragile design of the mech unit sets it up for easy failure." - https://www.team-bhp.com/news/understanding-vw-skoda-dsg-dq200-failures-detail
And following a link in the linked article -
"Synthetic oil was replaced by mineral oil. As synthetic oil had corrosive additives which were eating away the main mechatronic seal. And was conducting electricity and shorting the TCU/Mech unit. All oils conduct electricity but synthetics are much more conducive compared to other oils. So, this solved the shorting issue." - https://www.team-bhp.com/forum/technical-stuff/288240-understanding-vw-skoda-dsg-dq200-failures-masterclass-srinivas.html#post5886005
The make up of the blend and additive package can be altered but the likes of VW always seem to have their own demands rather than letting specialists er, specialise, possibly for saving a few cents on each box fill by sticking with cheaper blend.
German auto engineering (good) quality started to drop off around the turn of the century but a good reputation takes a lot longer to lose than a bad reputation, more than 25 years it would seem.
VW did not in this case falsely claim anything.
There was Internal Corrosion and issues with the sulphur. Humidity was the issue.
What was false was a Global Recall excluding Europe yet Climate in parts of Europe or the UK could be just the same as New Zealand, but there there were only hundreds or vehicles needing a new MCU.
Plenty articles from 2012 around, including Autocar VW,s favoured mouth piece where they said no need for a UK recall.
China & Asia got 100,000 miles / 10 year warranties given. 2 years later in the UK / EU / Europe a Service / Workshop campaign.
** Never a retraction, apology or anything like. & never a mention of the failures of late 2012 to 2013,s never given a Service Campaign.
I'm not an expert in anything, including lubrication oils, but the G052512A2 that German oil suppliers sell seem to me to look like a pretty standard (SAE) 75w, (API) GL-4 transmission oil similar/same(?) to the oil I used in my 1970s car's transmissions until a few years ago, crude old transmissions they were too.
https://pim.liqui-moly.de/pdf/en_GB/liqui/31/P004182
https://webservice.tecalliance.services/pegasus-3-0/documents/20803/564045180275377
OK thanks. But it still seems odd that the great German engineers would allow an oil company to give them the wrong oil for their gearboxes, must have been the oil company's fault, surely not the German engineers, sulphur's been in gear oils for a while. wink
VW holding back stuff from their customers, again surely not. It wasn't the first time a manufacturer has been economical with the truth and I'm not the last.
I's a bad show but that's how thing got and are with the general motor trade.
'34F7'.
Hi. Thanks for the info. Im happy for the confirmation that it was the Mechatronics central hydraulic fluid that was switched from synthetic to mineral, as I suspected all along. As such my car is newer and definitely has the right fluids so nothing to worry about on that front.
Coincidentally Im from India and a member of the TeamBHP forums so Ive already gone though all those threads in detail, this thread was mainly to double check and keep my sanity intact and verify facts with people who have actually gone through the recall. There was no recall in India and the gearbox was introduced here in 2013 I believe.
However, it is mainly this thread : https://www.briskoda.net/forums/topic/444027-201718-dq200-dsg-34f7-service-campaign-any-further-issues/
which made me doubt which of the two fluids was problematic. A member has posted his invoice from the recall and the part number for the fluid that was changed matches up with the GEARBOX oil and not the MCU fluid ! The quanity (2 litres) also lines up and reinforces that fact that it was the Gearbox oil that got swapped out atleast in this particular instance of the 34F7 campaign.
Does anyone have a picture of their invoices from the recall ?
