Can you retrofit rear parking sensors?
We have just bought a Rapid Spaceback SE and it hasn't got parking sensors. I'd like to have them for when my daughter drives it so can they be retro fitted?
Yes - two options:
1) source the original factory sensors and loom, have them installed and coded in. Expensive but will look OEM.
2) just buy any old set of generic reversing sensors and have them fitted. They take power from the reversing light, thus they only common when you are in reverse. Perfectly good and many can either supply the sensors in the same colour as your car (or close enough) or you can have them painted.
There’s also a third option - don’t worry too much about buying reversing sensors and instead teach your daughter how to reverse without hitting stuff? 🤣🤣🤣
Turns out it was an SE Tech and already had them! Thanks anyway
