Heated nozzles: where in BCM and coding?
Hi there!
While I'm accomplishing the latest retrofits, I'm planng the new one, like the heated nozzles; I found a very convenient kit with OEM one, but I have some questions.
In details I need to know:
  • which pin do I need to connect in BCM?
  • is there any specific command to turn them on via infotainment?
  • can I just replace those I already have? or do I need a separate circuit for water?
  • the negative can be screwed to a bolt in the hood?
  • do I need to have the heated front windscreen too?
Look Here:
Control unit 09
Adjustment
Window heating
Washer nozzle heating
installed
what about the pin on the BCM instead?
Edited by Benja77
I think buying an access for Erwin would definitely be money well spent given your number of retrofits
