Odd goings on internal lock
Afternoon all. Have had a search and can’t quite seem to see the same issue but wondered if anyone here has had the following:
2015 Superb Estate L&K. Drivers door internal lock / unlock button on door card. The button will work if locking the car (locks all internal doors).
However it won’t unlock any doors. To let my hostages free I either lean across and press the passenger door button (which works both lock and unlock fine) or I open the door using the handle which unlocks all doors.
Anyone come across this? Coukd it simply be the door switch has lost a contact or is something more tricky in an ECU somewhere ?
Any help much appreciated.
Hello again. Replying to myself as sorted! (For the time). Found the below post and helped understand. Although the pencil
Trick didn’t work - a Little manipulation (and a small piece of cardboard to bring the circuit board closer to the surface rocker switch) has worked wonders
Sorry for taking everyone’s time !
Don't worry about it. Thank you for coming back and letting us know how you resolved it!
