Wheel bearing
Wifes yeti has started to get a noisy wheel bearing, is it something I can change on my drive way or do I need a press ? Am going to have a look this weekend and see what wheel it is , it's a 2015 4x4 , also where would you get a replacement ? Thanks
O and what's the best spine tool set to buy ? Is they a set that has all the skoda sizes in if that makes sense Going to treat myself to a set thanks
I enjoy working on my own Yeti. Most recent job was a water pump change. However, I now draw the line at "heavy" stuff like suspension and wheel bearings. You need a long breaker bar plus the car at sufficient height to be able to swing it. You also need to borrow or buy good quality splined sockets. The fasteners will have enjoyed years of corrosion inducing muck and might need an impact wrench. So my advice would be to use a good independent VAG garage. Rear wheel bearings have changed design over time, so a VIN check might be needed to get the correct one.
What spine set will I need ? I do have a long braker bar so am going to try do it my self don't really have the funds to pay someone else
