Rear wiper hose!!
I'm sure I've seen something about this on here before, but i can't find it now. (eyes painted on :rolleyes: )
Anyway............my rear washer jet pipe has come off and cant find were it is!
I've remover the trim on the boot lid, and it's still attached there. I've remover the passenger side arch trim carpet thingy, and i can't see any pipework in there at all............. But when i activate the pump, a puddle of water appears from the passenger rear corner!:confused:
Can anyone give me a clue were to look please? :thumbup:
pull back the lefthand inner arch trim panel next to the rear seat.
you will see a wiring harness loom . the pipe is hidden under there. you will find the coonector bit about 3/4 way up the pipe is black.
you will need to drain the back inner q panel box section out as it will be full of water .do this by removing the rubber grommet at the bottom of the panel . just push it out from inside of the car on to the flooroutside the vehichle .
also chech your passengerside rear foot well as it might be wet too
