Power Steering Packed Up - Help
Hi,
I am a noob to this site and there seems to be a lot of info here.
My power steering has packed up - I took it to the dealer (HL Austin in London) - said he could nt communicate with the power steering unit.
He used a machine and tried option / test 44 I believe - The power assistance test - That failed saying it couldnt communicate with the unit.
Anybody like to say wether the pump needs replacing - The guy seemed pretty new and didnt come across as certain.
Assuming you are talking about a Fabia?
Fuses ok?
Just the one unit? :confused: Could it talk to all other modules? I would go with the above advice first. :)
I ve checked the fuses - They all work sweet.
Sounds like it is a pump then if the pump is powered up.
It could talk to the other units - Saw the ECU responding - Just not the PAS system.
Any ideas - I didnt understand what this meant :
Which advuce ?
Which advuce ?
I was referring to Ross' fuse check. :)
Have you checked the fuses in the battery tray?
