Fitting new brake servo vacuum pipe - 1.4 16v engine
Hello Skoda enthusiasts,
When replacing my brake servo pipe with a now one, is it simply a case of pulling out the old and plugging the ends in directly?
On the new one, one end has a rubber boot type thing and the other end is plastic with a bit of ribbing on it.
Are there any gaskets/ seals etc necessary for a snug fit? Wanted to check before I make anything worse...
Any advice appreciated and thanks in advance.
HJ
  • Sponsor
It will be easier to remove the servo end of the old one if you deplete the residual vacuum by pressing brake pedal a few times first.
A bit of saliva as lube on the new one will reduce the force required to insert that end.
Other (inlet manifold) end may have a metal clip on the original, not sure.
As long as new one is a snug fit that can probably be replaced by a cable tie, or small jubilee clip, but don't over-tighten, the spigot is plastic.
Thank you Breezy_Pete for the tips. Seems hard to stuff it up but you never know. I am capable of anything.
