New USB connection
Hello ,
Trying to install a new usb plug in order special for carplay.
I asked before but no reply so i try sometring new,. I wonder if any of you tryed install a new wire connection fuse box inside car /dashboard and on other end an usb plug.
I saw several choices on allx' allready equipt , just to install it.
Can you advice me at at what fuse nr i can plug it in order to work just when engine is on/key in ?
Would work or iis needed something else. O3/2016
Thanks !
There are many feeds on this in Briskoda. Have a look in the Audio and Security section. In summary, it will require an upgrade to your USB socket and an updated MIB system. You are probably on an MIB1 system. Depending on the model, you could easily upgrade the headunit and screen. Speak to our resident guy @pab567 for further assistane.
Thank you for your reply. I already looked around but I will do again where you also mention.
Have a nice day!
PM me VIN and I will check details
Hi ,done.
Thanks for your reply)
Edited by MihaiRo2022
Nope, I don't have any PM from you
Please me so kind and check again, is an older message that i replyed now. Can't make a new text(missing those recuired 20 posts befor being alowed)
I sent you PM
