Skoda Update
Hi!
Recently updated to ME3.7 via OTA (Don't know if it will show up here). I haven't updated the map yet. (Some problems with old disk and USB C to USB A adapter. Tested with USB C memory stick, it gets up. But doesn't update) But does anyone have an idea of what needs to be updated / is old here? Which possibly Møller needs to update?
Kan være et bilde av bil og tekst som sier 'Resslyngveien LTE 動品量 s#ll. 8:22 ysteminformasjon Delenummer for enhet: 5LA035816Q Maskinvare: H20 Programvare: 1751 Maskinvare visnings- 90 betjeningsdel: H7 Programvare visnings- 0 betjeningsdel: 110 Navigasjonsdatabase 21.11 Medie-codec: Vis alle oppdateringer 22.0° Hjem n Favoritter 星編星 Meny'
It sounds like your ME3.7 update went through, but the map update is being blocked by the adapter or disk issues. Using a USB-C memory stick directly is a good workaround. Usually, the dealer or Moller can provide guidance on which files are current and help ensure the system recognizes the update properly.
