Which mini fuse is switched?
Hey!
I want to see which mini fuse is switched on the O3 - https://www.startmycar.com/skoda/octavia/info/fusebox/2019/gen-mk3#anchorfusebox1
Any ideas? I am trying to install a dash cam and every mini fuse I have tried seems to be live.
The piggyback fuse I have is the mini one, and cannot find to buy the standard size piggyback fuse locally, so if I can get away with the mini one it would be better.
Cheers :)
1 hour ago, DanielFenech said:
Hey!
Cheers :)
UPDATE : With the multimeter I tracked which fuses are switched, and unfortunately most of the few I found switched are too tight to fit a piggy back. In the end I used the F36 mini fuse which is the Actuator module 1 for right LED headlight. I will wait a couple of days to see if it generates any fault codes or errors in the headlight unit, or drains the battery. So far it seems like it works fine.
Do you mean ignition live? I used the BSA fuse - I don't have it on my car, but the hot side is still ignition live.
I worked it out using the mini fuse for the actuator module of the right LED headlight :)
