Extending air con control wires?
I know this sounds a little strange, but has anyone extended the wires to the aircon control panel at the bottom of the dash? I want to move it elsewhere and had a thought that the signals may change over a distance hence messing it up?!
Might be completely wrong but thought someone here might know:)
any knowledge mucho appreciated!
i very much doubt that moving it should cause any problems.
Where will you reposition it?
right, as soon as I get my other project finished I shall experiment!
either in the glovebox as it is usually just set at a temp on auto, or if there is enough room into the space infront of the sunroof controls...
I could do with hiding my controls from the gf so I did not end up with a baking hot car....!! Maybe I should add a tamper/child lock to it!!
