Injector Coding
Can I ask if it's necessary to code injectors on a 2013 1.2 tsi? Like you would on a Diesel engine. I have a fault with the Cyl 3 fault code. I have swapped Injector cylinder 3 with cylinder 1, expecting the error to move to cylinder 1...it didn't. I suspect that the injectors are faulty. It's had a new head gasket, plugs leads and coil to date. Any help much appreciated. Thank you
Not a simple fix like this youtube video shows, is it?
I wish..
