strange noise?
i am getting a strange noise coming from the car when i turn the sterring wheel it is more noticable when the car is not moving it sounds like water moving/flowing around is this perfectly normal or should i be worried?:confused:
have you got pas fluid leak or has the level in the resovoir dropped below the minimum? it is possible that you have air in in power steering circuit.
there is no leak but im not sure about the fluid level because i cant really see where it is meant to be up to. also i have had someone mention there might be air in the system as the steering has become heavy if this is the problem how would i go about getting rid of the air?
