problème module 5F
Hello,
After purchasing my car ( skoda octavia 4 2023 sportline 2.0 TDI ) in Germany and returning to Belgium, I installed the OTA update to version 1989.
Following this update, I performed a full diagnostic scan using my Topdon Phoenix Plus diagnostic tool, which detected numerous fault codes across many of the vehicle's control modules.
Unfortunately, I do not know whether these faults were already present before the update, as I did not scan the vehicle beforehand.
Based on my research online, as well as information gathered through ChatGPT from various technical sources, it appears that these fault codes may all be related to the 5F infotainment control module. It seems that this module is not communicating correctly with the other control units, causing multiple communication-related fault codes to be stored throughout the vehicle.
I have attached the diagnostic report. Could you please review it and let me know what you think?
I will also be visiting a Škoda dealership here in Belgium. From what I have read, there are several TPIs related to OTA updates and the 5F module. I hope they will carry out the necessary repairs under the vehicle's warranty, as this issue is clearly causing problems.
Thank you very much for your time and assistance.
Kind regards,
2026072618274146908.pdf
