Oil Change 2020 Octavia 4 1.5 Tsi
Doing my first Oil change on this car. Presuming the filter is76mm 14 flute. Is clearance sufficient to use a 3 Claw tool or 14 flute 76mm Cup tool. Also sump bolt purchased is 29.5 mm total length. Is this the correct part - M14x1.5 Engine Oil Sump Drain Plug N90813201? See photo below.
Thank you
PoloPaul
