G65 sensor no signal
Code reader showing no signal to both G65 & Air quality sensor, I’ve replaced both sensors with Skoda parts from dealership and still error code is showing, Aircon is non operational.
Any help would be appreciated
Hve you checked any fuse(s) that supply both G65 and air quality sensor?
Yes I’ve checked the listed fuses and can’t see any issues. Is there other sources that could cause this? AC was working fine before this issue.
Regards
Sounds like a wiring diagram would be useful to know where the G65 and air quality sensor connect to?
