Chip Protection on Sills
Did Skoda apply any stone chip protection to the lower area of the sills as standard?
Do you mean PPF, or actual underseal?
Underseal, beneath the paint.
On my mk2 octavia and sons mk1 fabia the lower outer sill and inner has an orange peel effect which is thick plastic stone chip protection then overpainted with gloss colour. They both have(had) clear plastic on rear wheel arch/sill area
Alasdair
Thanks for that, that is what my 2018 Fabia estate has on the sills. I assume therefore it is a factory finish.
its fairly thick as I had to remove some to patch sills on my old octavia. Its good protection but on mine over time moisture got behind it and ended up with holes.
Weird thing is my sons mk1 is a few years older 55 plate and its still perfect but my 58 plate octavia is now a parts donor car as sills have gone past repair.
Alasdair
3 hours ago, DWS1953 said:
Factory.
It’s pretty crap to be honest - gets brittle and starts to peel. It’s worst on the jacking points if someone has ever used an emergency jack, or one with the incorrect pad.
For the most part, it does the job well enough.
Think the older skodas were painted better. As said my sons mk1 fabia paintwork and underside is pretty good for a 55plate but both my newer octavias are rusty. Old one under rear and sills/wings plus middle of drivers door panel and newer 1.6tdi under rear,sills,front wings and estate boot lid around nplate and nplate lights.
Alasdair
