Thinking about an Elroq, but...
Insurance quotes are so different from the various providers. Those advertising Special EV insurance like Admiral can be a ridiculous price. As to Comparison sites. Compare the market, showed me better prices than either Confused.con or Supermarket. Com. This year Ageas has provided me good cover at a great price.
Edited by Evolution13
Just done a quote for late September and it's an additional £159, which seems fair enough when the value of the car is £45k
My understanding (willing to be corrected) is that the Elroq 85 has an NMC battery which means the best procedure for slower battery degradation is to maintain the charge between 20 and 80%.
It is ok to charge to 100% for range flexibility on a longer journey, and ok to run down to low percentages if you immediately charge it. It is leaving the battery for a long period at either higher or lower limit that causes the greatest degradation.
LFP batteries (in the Elroq 60) are different insofar as they are far more tolerant of extended periods at the limits and even benefit from regular (weekly?) 100% charges to maintain correct battery level monitoring.
I do get very confused on the vehicular heat pump option and what it does. I mean I understand how a heat pump works, and its efficiencies, and even have very effective reverse cycle air conditioning in my house.
In an ICE vehicle the heat is supplied from the engine waste heat and the cooling from an engine driven cooling heat pump and the combination allows control of temperature and humidity, so that you can clear the condensation from the windows without freezing your man bits off.
So, if you opt for a heat pump then it cannot just be a reverse cycle unit since you need both hot and cold elements to achieve the same de-humidification.
Then there is the question of how battery temperature is controlled, essential for fast charging and longevity (original Nissan Leaf being a prime example of the consequences of not managing battery temperature). Does the battery have separate heat pumps circuits or share the passenger cell facilities?
Edited by Gerrycan
MEB cars have a separate battery heating/cooling loop but share the car's aircon unit for cooling. There's a three port valve that controls flow to the coolant loops.
I have no idea what batteries are under this one it might still be NMC (Nickel Manganese Cobalt) and as it's a MY27 car it comes with a 84KwH battery rather than 82KwH, plus loads of software updates & differences
Cheaper models tend to be LFP (exceptions in Korean vehicles) and more expensive models use NMC due to better energy densities.
I think it is important to clarify since it may affect how you (should) live with it.
Most of the year it'll be mundane stuff, loads of short hops for groceries and (I nearly said petrol then! LOL!) social stuff, but there's several times of year when I do 200-300 mile journeys, which will almost inevitably now require a layover for charging. But the way fuel prices are going and my lack of enthusiasm for the out & out brut power of the RS, I'm hoping that this change will calm me down a bit, especially as I get older and I now have medical conditions with high BP/HF Depression/anxiety amongst them.
With an Elroq 60, the lesser charge means in NMC technology, you'd have free space (I imagine similar idea as for old vs new e-Golfs).
For Skoda as a manufacturer, the less-dense LFP technology most likely utilizes that theoretical void.
The LFP offering is also seen in Tesla model 3 etc. I found it preferred, as it is less strict on the charging practices (takes 100% more frequently and by recommendation), and also seems to be a technology which is less prone to fire hazard.
So far really chuffed with ours for even long journeys, even if driving an Octavia is a good thing.
My MY26 VRS had the 84kWh battery, now my new MY27 VRS has the 82kWh which is the opposite
Weird isn't it.
Sure is, it's probably just a "procurement" thing?
