Changing the Superb 18' Service Interval value
Hello,
For some time now, I have been trying to change the service interval on my Superb from 15,000 km to 10,000 km.
The car displays the Service Reminder Status on both the infotainment system and the instrument cluster whenever a value other than 15,000 km is configured, regardless of whether the warning value is set to Warning Off.
I have spent quite some time experimenting with different combinations of the maximum and minimum parameter values in ESI, SIA, and FIX, as well as combinations such as Good Oil and Poor Oil, in an attempt to change the service interval type from flexible to fixed. The reset button for the service intervals on the instrument cluster automatically changes the oil setting to Poor Oil, but the reminder still appears when starting or switching off the vehicle. I even tried performing the reset with the hazard lights switched on.
The reminder only disappears when the service interval is set back to 15,000 km and appears when is close to 200 km.
What are the correct steps to configure a 10,000 km service interval and a reminder for 200km left till service, and where am I going wrong with the parameter combinations?
Best regards,
Fixed service Regime set for Non Long life oil or Long life if you want fixed is 15,000 km / 9,400 miles.372 days. (so no setting at 10,000 km.) Flexible / Variable 30,000 km / 18,000-20,000 miles / 24 months.
Ah, i see ☹️ .. Thanks for the clarification.
Bringing this thread back, as I've done quite a bit of experimenting with the car's coding. It turns out that changing only the SIA max value for the oil service and the FIX max value for the inspection with poor quality oil set did the trick and allowed me to set the service interval to 10,000 km. Everything else is set to 15k.
Edited by Ned1
