Exhaust mounting question
Noticed my new exhaust (three weeks old at least) has a litle rattle start yesterday
and today is was a big ratle
had a look under the car and the second to last mounting had come off
the one next to the rear passenger wheel
it is just a bolt through a bracket through the rubber mount but no nut on the other end
fitted a new washer and two nuts (hoping to lock it on) and the rattle has gone
Is this mounting normal
ive never noticed a rubber mount bolted on i thought they normally hooked on
cause you cant bolt it up tight beeing rubber wont it just keep coming off ?
What exhaust is it?
Custon made jobbie :rolleyes: cat back
Well if its custom it can have any type of mounting on it.
Its the mounting up to the car wich came off
i thought they would be the same on all exhausts using the standard mounting points
the exhaust itself is just a rod that goes through the rubber part and had a hook on it to stop it sliding off
might have to dig the digital camera out tomorrow
The standard hangers bolt upto the car using two or three 13mm bolts depending on which mount it is.
Sounds like everything is as it should be
it was a 13mm nut i put back on
although its was the mounting between the one in the pictures and the one the backbox would hang off
just hope it doesnt come off again
