3000 miles under my vRS belt, a few questions....
Hi All
Brand new vRS picked up in July, and with 3k under my belt it's so far exceeding all my expectations, I'm delighted. It's used for regular long haul 200 mile journeys, so the tech and convenience to make it easy to drive are super important to me. With that in mind, after living and experiencing the car, and also ferreting through the handbook, I have a few possibly stupid questions...
  1. Pan Roof Blind. Is there a way to make it open/close automatically on unlock/lock like I could on my outgoing Discovery?
  2. I often (once a week) get a message at the top of the screen (over a blacked out screen) about the system setting(s) being updated, asking me if I want to save them. But I don't know what setting(s) that refers? All I know is if I press accept, it switches me out of whatever mode I was in, and back into default.
  3. I religiously use Waze as my Sat Nav (via CarPlay) including all alerts etc. With that in mind I have no need for the on-board sat-nav alerts, but I can't seem to find the area where I can turn off the in-built Skoda Speed camera warnings which I assume are being triggered by the onboard mapping software? When it triggers, the screen goes black and asks me to acknowledge at the top of the screen, which is annoying because when I'm on the M25 the car is shouting at me twice (once Waze, once on-board) about speed cameras, and also blanking the screen which I have to clear each time.
  4. The minimum distance on the ACC leaves quite a large gap (much bigger than cars I've owned in the past). This means cars will often jump out of lane 1 or 2, forcing the car to brake and maintain the another minimum distance. I can make the gap bigger, but seemingly not smaller. Any way to override this or am I stuck with the preset distances?
  5. The wireless charger trays don't appear to charge the phone above the level the phone is at when I place the phone (iPhone 15 Pro Max) into the tray. I'm connected to CarPlay and streaming Waze and Spotify, but It'll only maintain the level and not go down, regardless of how far the journey is. If I want to charge it up over the level I seemingly have to plug it into a USB charging post.
Thanks in advance )
Disappointing no one has replied to you yet. Kodaq owners must be shy )
I'm not a Kodaq owner but should be this coming week, although only the basic PHEV version offered here is Australia so no pano roof and I'll be suffering from 'techshock' when it does arrive due to my current cars being pretty old.
Kudos to you for checking the user manual before asking, surprisingly few do.
If the Pano roof opening and closing link to unlocking and locking is not in the user manual, then it is probably not an option. Might be worth exploring VCDS options but if you cannot operate the opening/closing from the screen (only the physical switch) then I would be pessimistic.
Page 141 in the Kodiaq User Manual tells you how to turn off the speed warnings or increase the warning threshold.
Unlikely to be able to shorten the minimum distance on the ACC (VCDS again?). Best bet would be to estimate the minimum distance it is leaving and check with the dealer if it is correctly set.
I was initially stunned when I drove in the UK (on the M25) by how close people drive at speed to the car in front. Took me a while to adjust to prevent the same problem of people jumping into the gap I left. Of course, BMW drivers did it without indicating.
I've no real experience of wireless chargers but they are only rated for 15 watts and even that rate may be compromised by whatever protection holder you may be using for the phone?
Glad you are enjoying your car overall though.
From my own experience the wireless charging trays in cars are great in theory but poor in practice because they allow the phone to get too hot, which isn't great for the battery in the long run. My Kodiaq will just about charge an iPhone 14 Pro while CarPlay is being used on a long journey, but every so often I get a message that charging will resume when iPhone temperature returns to normal, and by that point it really is glowing.
My solution is to use a cable on longer journeys. You can get USB-C cables with right-angle connectors now, and one 20cm or so in length is enough to pick up the phone without having to unplug each time. Happily it coils underneath the phone and stops it charging wireless too.
I think until car manufacturers realise that wireless charging trays need their own air conditioning we're better off with a wired charger.
On 28/09/2026 at 17:38, Windy-Miller said:
  1. The wireless charger trays don't appear to charge the phone above the level the phone is at when I place the phone (iPhone 15 Pro Max) into the tray. I'm connected to CarPlay and streaming Waze and Spotify, but It'll only maintain the level and not go down, regardless of how far the journey is. If I want to charge it up over the level I seemingly have to plug it into a USB charging post.
Su8perb owner here but its much the same:
2- Seems to be a known bug. Watch out for it randomly changing settings. Mine occasionally turns of the autohold brakes.
3 - I suspect these are fromn the "Traffication" system. Lookm in the apps on the car to find the Trafffication app an turn off the alerts there.
5 - If I'm using navigation from Carplay for any time I always use a cable for charging. If nothing wlse the phone gets really hot when navigating and wireless charging which doesnt do the overal battery life any good.
When we collected and drove our new Kodiaq PHEV home the other day we noted that the wife's phone case stopped her phone from sitting flush in against the surface in the wireless charger, but she could not be bothered to remove it from the case to see if the charging would improve from the apparent very slow rate.
The blurb for our car says that the wireless chargers are cooled. Will probably experiment with all that when we go on a long trip in just over a week.
Edited by Gerrycan
Wife managed to get her Samsung S23 into the wireless charger with the phone base flush with the charger surface, and still in its protective case.
The phone then charged slowly, but commensurate with the claimed 15 watt wireless charger rate.
Recently Browsing 1
