Another Fabia mk3 wiper issue
Hello brains trust.
Family member has a mk3 my21 Fabia. Right hand drive model.
Front wipers do not activate no matter wiper stalk position, rear wiper works via the same stalk, however zero water coming from the washer bottle to either front or rear wipers.
I’ve checked marked fuses (the fuse box in the engine bay and also the indicated fuses under the steering column) all indicated fuses have power at the fuse and illuminated both sides using a test light/lamp.
I appreciate this may have been covered previously and sorry if I’m not seeing something obvious.
I couldn’t hear any ticking noise from the bcm however I was at the time more concerned in checking fuses.
PS the vehicle is an Australian version hence RHD.
Thank you
For two functions missing on the same stalk, I'd suggest checking the stalk itself first.
@whitevx did you fix the fault?
Wipers are working, the pump isn’t. When testing front and rear have power each side of the plug for the pump (1 side rear, other side front - when pull/push the stalk) I’m inclined to think the pump isn’t stuffed.
Any opinions or thoughts ?
If the washer pump is actually operating without any fluid appearing at the rear nozzle, I'd be checking for a blockage, kink or leak - possibly where the washer hose loops between the body and the rear hatch/tailgate.
