Cabin heater easy way in with cabel from enginebay
Hello from Sweden!
We have just bought a Kamiq for wifey and i need to install a cabin heater. Does anyone know if there is an easy way to get a cable from the engine bay in to the cabin? I did not find an as easy route in as i remember doing on the Fabia Monte Carlo she had before.
Hi, i took the clutch cutout inside.
How did u do it?
Any tip on how to route and Where to ground the 230v input in the front ?
Left or right side and where did u ground?
Not sure on kamiq but I managed to get a bit of stiff fence wire at the grommet where cables come through bulkhead from ECU etc on my old Octavia and an Old Seat. Then pulled cable back through. Easier from engine bay on mine. On some of the grommets there is a small nipple that you can cut off and feed through there.
Alasdair
