Superb Matrix Headlight
Hi guys!
Quick question. I have a 2020 Matrix headlight and the numbers are 3V1941015D 3V1941016D. Sadly in an incident both are cracked and i want to buy used one. Hardly i found both and it was made in 2024 but the letters are not the same. (3V1941015E, 3V1941016E)
Is it plug and play if i buy the 2024 or do i need to code something?
Thank you!
Just looked the numbers up, both valid for S3, also shows those numbers as left hand drive versions. If you swap your modules over, it shouldnt need coding, but will deffo need alignment with workshop equipment. Not tried out my Beissbarth MLD 9000 on matrix lights yet,(bought cheap for retrofit of LED lights on T6 Vans) may get a chance if I buy the car I'm looking at next weekend. I can't find anything published why they wont fit on ETKA, PR numbers are the same for both. Always a bit of a gamble not using the same numbers, both numbers are valid so one may be a high and one a low version.
Edited by 3T51704x4
Typo
Yeah so i bought two headlights with new oem numbers (2023) the driver site works well but the passanger side not do the calibrazion when i turn on the engine. There is not a single error or code in vcds. I went with it to my dealership but they says to me that the calibration motor get bed inside it.
If they say its a motor, can you not swap it over from your cracked one?
Ive never seen a motor fail in an undamaged light, normally broken wires from moving the unit up and down, think Ive seen a tech bulletin for this but on Audi rather than Skoda.
Yeah they said this. But i dont know you can see and hear in this video.
Its clearly working so I would suggest the feedback signal wire could be broken which (if it is) will prevent the basic settings from setting correctly.
Do you mean that wire that one is it inside the headlight?
Yes. The solid wires drawn in the CFD for the headlight are actually normal wires.
So it will have a live an earth and a feedback to the module.
Edited by 3T51704x4
I am going to watch it tomorrow. What if it is have component defense?
In the UK we call it CP Component protection. Your dealer would have been able to release it IF it had CP using ODIS I would have thought using function enabling.
Did your lights come with new modules or did you swap them from your old lights?
So the “new” ones are used ones. (Perfect condition, from the outside.) So the “new” ones are built in, with the factory control module( i bought it with it.). I tried with the old one but the symptoms are the same sadly. But if i just unplug it and plug the connector to my old one, that one works perfectly. I mean here that the old one do everything except the new one which is not doing the calibrate and not leveling.
Recently Browsing 3
