Fabia 2011 1.2 TSI - DSG 7 speed gearbox help
Hi all I am fairly new to this website and definately new to being a Skoda owner!
I purchased the above car a few months ago and as we (my family and I) usually do all our own car maintenance although we are pretty clued up I purchased a Haynes manual for the car it covers the 'usual' stuff but unfortunately it doesn't cover certain areas like the DSG, I want to replace the oil in the gear box and need to find a definitive answer as to what oil type, the quantity and also how to change it.
So if anyone out there is able to help with any advice or trusted web links it would very much be appreciated.
Thanks 🙂
I seem to recall there's some reasonable step by step guides on YT, e.g.:
We've the same DSG in our Polo. I've considered changing the oils, but not yet made it past the considering stage.
Gaz
^^^ That is different from doing a DQ200 on a 1.2 or 1.4 TSI Fabia. Do not remove the starter motor. @Catwoman If your car is a 2011 than there was a Service Campaign after 2014 to change the oil from Synthetic to mineral & a software update. '34F7' Dide the car get that. Sticker in the spare tyre well. There are 2 oils to change, in the gearbox and in the MCU. If changing the oil best do both. Best know what you are actually doing.
Edited by Evolution13
Hi Evolution, thanks for your reply. I have only owned the car since the beginning of the year so can't confirm about the oil change however I have had a look in the tire well and there are 3 stickers, one is I believe the original one put in at the time the car was built it has all the details of the car, engine, paint etc.. then 2 local dealer stamps (see pics) one is dated Dec 2014 so it might be that the work was done? Wasn't quite sure what your "'34F7'" meant.
Re 'best to know what you are doing' I totally agree, my brother who does any work on the cars is a mechanical engineer and is very switched on, he has changed oil in regular gearboxes but has never worked on a DSG box in a Skoda. The Haynes paper manual does not cover the DSG and beside YT I am struggling to find exact info on what to do/ don't do for this car so hence my request here!
Gaz
Hi Gaz, just had a quick look at the YT it's for a 1.6 diesel, the under the hood layout is different to mine, but thanks for the link anyway!
Mine is a petrol 1.2
Personally i would leave it as is. If the DSG functions properly.
Hi thanks for the attached, neither of the 2 stamps seem to show the 34F7 stamp, I could contact the dealership and ask them to confirm.
It should be on the records as done or not done. Also what other Service Campaigns, maybe track rod ends, maybe Heated Seat Elements if there are heated seats. Then there was a fan issue. But if '34F7' not done and DSG OK i would still not touch it. For a 2011 1.2 TSI There is can update of the Timeing Chain & tensioner. might have been done. There should be armoured Plug Leads, especially on cylinder 3. This was an update. When were the Spark Plugs changed? When was the Air Filter changed or the brake fluid replaced. These are the first service things i would do.
