Skoda Felicia 1.6 GLX idle problem
Hello.
I have problem with idle at Skoda Felicia 1.6 GLX.
Problem starts about after one year when i replace throttle body.
Usually high idle is present when outside temperature is high, about 30 to 35 degree celsius and the motor is cold.
Now these days when temperature is drop i still have problem and is even worse.
It goes up to 2500 RPM when the motor is cold.
Sometimes when cold start is normal when i drive some kilometers it starts again and idle keep holding for about 2000 RPM.
Sometimes the motor was cut off during low speed and warm motor, but this fault is gone now.
What can cause this idle problem?
Edited by JohnNovak
text correction
  • JohnNovak changed the title to Skoda Felicia 1.6 GLX idle problem
