Bonnet support clip come away
The clip that holds the bonnet support pole has come away and will not go back in place. I bought a new one from Skoda for £3 and I can’t figure out what I’m doing wrong. Can anyone advise how I get this yellow clip to lock into place. Image below is a picture of the clip I’m having trouble with. It’s a library pic not my actual car.
Edited by Jonop
I’d guess, that it has an expanding pin fitted into it, so you fit the support down into the hole then press/punch the expanding pin fully down and that will lock the clip in place.
That’s what I assumed, similar to the parcel shelves. But when I push the pin down it doesn’t spread the tabs out very much and it just falls out.
Can anybody do me a favour and take a picture from underneath the yellow clip, I’m wondering if there is some type of washer on the underside.
Did you manage to sort this out?
At least on my wife's 2015 VW Polo 1.2TSI, the area under this clip is hidden as it is on a plastic body part that bolts down onto the next metal body part - probably the lock carrier in VW Group speak.
