Ambient air temp sensor on the wonk
Hello all, long time lurker, 1st time poster.
I'm having trouble with the (external) ambient air temp sensor. When I start the car in the morning (2010 CFGB TDI 4x4 estate) the sensor works fine, when I return to the car initially the sensor works and then it starts shutting down ---- on the MFD and then occasionally reads 58C then ticks down to the the actual outside temp and then shuts down.
I have a Carly scanner and I get fault codes for the circuit being too low, too high, with the addition of 'sensor for outside temp, resistance too small" at the instrument cluster.
I also get a faults for the air quality sensor, and the glow plug controller/relay and wonder if they're all connected?
Also I get error messages on MFD for various bulbs being out I.e DRL, side lights etc but, no fault codes stored so wonder if this is also connected?
So far I've replaced the external air temp sensor with a OEM part from DSD, replaced the plug and 100mm of the cable.
I'm wondering where the sensor draws power and that perhaps there's something wrong with the wire in, I've chased it back to where the two cable meet with the rest of the loom that serves the engine bay and goes through the firewall seemly to the instrument cluster.
I'm all out of ideas part from unwrapping the loom to see if there's a break in the cables or whipping out the clocks to see if there's an issue behind them.
I'm hoping that someone has experienced the above and can help me solve this conundrum because it's causing mayhem with the HVAC system
Recently Browsing 1
