Common issues and what to look for
Hi beautiful people of the MKIII Superb forum, I'm currently in the unfortunate position of where my MKIII Octavia 2.0TDI Estate is looking like it is condemed after an injector failed and has potentially damaged something with the Cam.
That aside I am looking into replacing it with a 2022/3 MKIII 2.0 TDI manual estate, so my question is what are the common issues with the MKIII Superb? How reliable are they? Considering I do about 45,000km. Is it fairly easy to service? I serviced my MKIII Octavia religiously.
I appreciate all insight into the MKIII Superb.
Rear tailgate door struts, water pump ( on petrol dont know about diesel ), window regulator's, thing that breaks in gear selector, rear tailgate door latching mechanism, noisy front suspension.
Think that's about it for mine ... 2015 Had since new now done 60k.
Replaced the disks, springs and usual suspension wear and tear items about 18 months ago.
Mate of mine did airport taxi runs his had done 150k with zero problems.
Edited by Nick_H
I'd echo @Nick_H's experience - brake discs and pads, shocks, springs and top mounts; and add the battery and air quality sensor. Read the fault codes if you can to pick up any hidden problems. I think the Superb is hard on the basic wear and tear parts because it uses Golf sized components on a much larger car.
Recently Browsing 2
