Battery light 1.0 mpi 59bhp
Hi folks, I’m having issues with various warning lights popping up uninvited on the wife’s Fabia, but one is staying annoyingly dim - the battery light. I’m assuming like most cars this comes on during ignition and the goes out on start up normally? Only its not coming on at all. Any guidance much appreciated.
Welcome to the forum.
The alternator indicator should light with ignition switched on - then immediately extinguish when the engine starts (alternator supplying power)
If you have a multimeter, test the voltage at the battery terminals to check if the alternator is actually supplying power - should be significantly above 13 volts when engine running above idle speed.
Lack of indicator light with ignition on, engine not running suggests the indicator itself may have failed.
Recently Browsing 1
