Regular False Tyre Pressure Faults
In the last month I have had 6 Tyre Pressure Faults arise (5 of which have been for the same tyre, Rear N/S). However every single one has been false as when I check the pressure it is fine and matches the opposite side tyre. I was leaning towards a faulty ABS sensor but my assumption is that I should also be seeing ABS/ESC faults also as it's my understanding the sensor controls this elements also.
Octavia III Estate L&K 2015
Anybody have any ideas or guidance?
From what I've seen in other posts, most likely to be the ABS wheel sensor - I'd suggest having the OBD checked for any logged DTCs and get the NSR sensor replaced if that shows up.
Is there any significant difference in wear between rear tyres?
Edited by Warrior193
question
I actually saw a video on this the other day. I want to say it was TikTok. I’ll have a look - but IIRC the guy was saying that the system was giving false alarms, but that both the ABS sensor and ring were absolutely fine!
The 2015 Octavia uses a Tyre Pressure Loss Indicator, not a valve sensor, so a false alert on the same corner can happen without an ABS or ESC warning light.
After you have set all four tyres to the handbook pressures, store the values. Ignition on, then either CAR, Vehicle status, Tyre Press. Loss Indicator and SET, or press and hold the SET key until the warning light comes on, a beep sounds and the light goes out.
If it still flags the rear nearside after a stored set, have the NSR reluctor ring and ABS sensor inspected for cracks, dirt or corrosion, and compare tread wear and tyre size with the offside, because the system is comparing wheel speeds. A lingering malfunction light can be an MOT Major on a 2015 car, so it is worth finding the cause rather than just clearing it.
Thanks. Good to know that the sensor can throw up pressure alerts without ABS or ESC so I'll get on the case with checking it out.
much appreciated.
Recently Browsing 1
