Rear fog light(s) not receiving 12V
Hello,
I would need help at fixing the rear fog light. Bulb is intact, the switch works and on the dashboard the indicator light for rear fog lamp turns on but at the bulb socket there is no power. Might be related that long time ago some cable burned and also the left driver door's panel lamp is not turning on when door is openend nor does the door open sensor is working for the driver's door.
the front fog lights work properly
When you say no power have you checked to a reliable earth or just accross bulb contacts?
Alasdair
I checked bulb socket contacts but the ground in the socket is shared with the other 3 lights (night/brake, turn and reverse) which work properly
Recently Browsing 1
