1.4 TDi Spluttering and Loss of Power When Up to Temp
Hi all, Not strictly a Skoda but a VW with the same engine.
My wife's Polo suffers from kagaroo-ing and loss of power when up to temp, but is perfectly fine when not to temp. No fault codes stored.
1.4 TDi BMS 2007. Starts and idles fine. Pulls well. All seems fine until the engine is at operating temp. Then the problems begin.
Seems to take ages to warm up too but with this cooler weather I'm not sure it is a problem. However Gauge shows around 50-70 most of the time.
Called AA when it first happened. Couldn't find a fault and recovered it to the VW Garage we use. Garage had it over 2 days and couldn't find a fault.
Things I'm going to do this weekend.
Change Thermostat
Change Engine Temp Sender
Remove and clean out EGR valve
Replace rubber vacuum hoses with new silicone ones.
Anything else I should be looking at??
TIA
Nic.
If it takes ages to warm up it could very well be the thermostat thats past it. My old Octavia was the same. Not bad in summer but cold weather took ages and just made it to 90 after a long hard run(normally sat at 60-70 and it would noticeably drop the minute I let car idle). Changed it and it was fine after that. Reckon your right in changing temp sensor at same time to rule it out. I would do the above first and if no improvement maybe EGR valve clean and check wiring loom to injectors. If the loom is dodgy it could be affected by hot temps and cause misfire etc.
Alasdair
Recently Browsing 1
