which oil? & torque for drain plug
Hi everyone.
I recently bought a 1.3L Felicia 5 door hatchback, 1998.
I want to change the engine oil, which grade of oil should I be using?
Also, the sump drain plug what torque should it be tightened to?
Thanks in advance
use 10/40 semi synthetic. and the torque setting is 30nM
any 10-40w, oil but check if it has VW 500 00 for VW engines listed on the back... to ensure the exact oil for the motor :D
I use CASTROL GTX Magnatec oil.... at
