Pre out cable for Fabia vRS symphony CD Player
If you are in the need for an external amp be it to power a sub or your speakers then you can keep your oem headunit and simply buy a cable that give you front and rear pre outs and also a switched power cable to be used to turn on an external amp. This saves money on having to buy an aftermarket headunit from the likes of sony, alpine, kenwood etc and keeps that oem look.
The cable is in fact a Blaupunkt part but it plugs straight into the back of the oem head unit. I've attached a link here http://www.bluespot.co.uk/stock/preamp.asp
I've being using the above cable since I bought my car back in 2004 with no problem. At first I was using it to power 2 amps (one for front comps the other for a sub)
By going by the Gain I've used on 2 amps now at a guess I would say the pre outs are rated at around 4v.
thanks for that info mate i have been looking for something like this as i dont want to ditch my 6 disk changer
just wondering how does it wire up and also will it work on my 06 fabia vrs
cheers aaron
You can make your own as well -
20 Pin Multi Connector Yellow Section
1. Line Out, Left Rear
2. Line Out, Right Rear
3. Ground (GND)
4. Line Out
5. Line Out
6. Switched Positive (B+ Out) for Amplifier
http://www.fabia-vrs.com/carkit.htm
i aint the best with wiring like that so think i am gonna order that cable if it fits can someone give me a clue as to if this will fit my furby
cheers
cheers
Perhaps I could draw your attention to the thread title -
:D :D :D
This shows the entire plug in all it's tri-colour glory (taken from Stu's site)
You can mix and match the three different sections - I'm currently only using the blue part for my Denison Ice>Link so the yellow would click in nicely on the other side of the socket.
:D :D :D
sorry bout that i thought maybe there could compatability issues with the 6 cd changer or they may have changed the symphony model since then lol
cheers guys
And the three plugs come on the end of an OEM changer cable.
  • 3 years later...
Hi all, I'm in a similar situation with my mk1 Octavia using a Symphony headunit. My stereo already has all 3 coloured blocks going into the 20 pin block. So where are the wires from the yellow section going to at the moment? I assumed the standard audio outputs were contained in the black and brown 8 pin connectors?
Can I use the yellow plug on the changer cable end to connect the amp to? This would save running wiring right the way through the car.
